Before you start using Quicken Mobile or Web, do the following:
Turn on Mobile and Web Sync in Quicken. You can turn it on when you register Quicken or at any time afterward. From the Quicken menu, select Settings, and then select Mobile, Web and Alerts.
Install the Quicken Mobile app from the App Store or Google Play, or go to https://app.quicken.com in your web browser. Sign in with your Quicken ID.
Supported mobile devices
You can install Quicken Mobile on these devices:
iPhone
iPad
Android phones
Android tablets
Supported mobile operating system versions
For the minimum iOS and Android versions that Quicken Mobile supports, see Quicken System Requirements.
